Use this command to clear the VSB chassis ID and VSB system ID if the chassis has not yet been VSB enabled globally.
| chassis-id | Specifies the chassis ID of the chassis to clear from the VSB system. Valid values are 1-8. |
| secret | (Optional) Clears any shared secret configuration. |
| lfr-priority | (Optional) Resets the LFR priority to the default of 10 times the VSB chassis ID. |
All command modes.
This example clears the chassis ID and associated system ID for chassis 2:
System(rw)->clear bonding chassis 2 This command will reset and clear the current running configuration on chassis 2. Are you sure you want to continue? (y/n) [n]?y System(rw)->
Print
this page
Email this topic
Feedback
