Use this command to configure the IKE map with the UDP protocol.
None.
None.
IKE map configuration.
Use this command to configure the UDP protocol as the means of message transmission for this SA. There is no default protocol configuration. Manually configure the UDP protocol for the SA to be active.
Use the “no” option to remove the UDP protocol configuration.
This example shows how to set UDP as the transmission protocol for the winRadius IKE map:
System(su-config)->crypto ike-map winRadius System(su-crypto-map)->protocol udp System(su-crypto-map)->
Print
this page
Email this topic
Feedback
