Use this command to return the port ECS ELIN location setting to the default value of null.
| elin | Specifies that the ECS ELIN location information value should be cleared. |
| port-string | Specifies the port or range of ports to be affected. |
None.
All command modes.
This example returns the location information ELIN value on port ge.1.1 to the default value of null.
System(rw)->clear lldp port location-info elin ge.1.1
Print
this page
Email this topic
Feedback
