Use this command to enable passive OSPFv3 on an interface.
| vlan-id | Specifies the VLAN number on which to enable passive OSPF mode. |
| interface-name | Specifies a VLAN in the interface-name format: vlan.x.y |
| default | Sets all enabled OSPF interfaces to passive. |
None.
OSPFv3 router configuration.
The passive interface feature allows an interface to be included in the OSPFv3 route table, but turns off sending and receiving hellos for the specified interface. It also prevents OSPFv3 adjacencies from being formed on the specified interface.
The “no” form of this command disables passive OSPFv3 interface mode.
This example shows how to enable passive OSPFv3 mode on VLAN 102 (can be specified as vlan 102 or vlan.0.102):
System(rw-config)ipv6 router ospf 1 System(rw-config-ospfv3)->passive-interface vlan 102
Print
this page
Email this topic
Feedback
