Use this command to add or remove an offset to the hop metric of an incoming or outgoing RIP route.
| in | Applies the hop offset to incoming metrics. |
| out | Applies the hop offset to outgoing metrics. |
| value | Specifies a positive offset to be applied to routes learned via RIP. Valid values are from 0 to 16. If the value is 0, no action is taken. |
None.
Interface configuration command mode.
Adding an offset on an interface is used for the purpose of making an interface a backup.
The “no” form of this command removes an offset.
The following example shows how to add an offset of 1 to incoming RIP metrics on VLAN 1:
System(rw-config)->interface vlan 1 System(rw-config-intf-vlan.0.1)->ip rip offset in 1
Print
this page
Email this topic
Feedback
