Use this command to specify the Source-Specific Multicast groups permitted to cross this interface in either an inbound or outbound direction.
standard-acl | Specifies the extended ACL containing SSM group permit or deny entries. |
None.
Interface command mode.
The SSM join filter applies an extended permit/deny ACL, specifying the source or destination IP addresses that define which Source Specific Multicast S,G pairs are permitted to cross the interface.
The “no” form of this command removes the specified SSM join filter.
This example defines the SSM groups permitted to cross this interface using the ssmFilter1 standard ACL on VLAN 100:
System(su-config)->interface vlan 100 System(su-config-intf-vlan.0.100)->ip pim ssm-join-filter ssmFilter1 System(su-config-intf-vlan.0.100)->
