Use this command to reset a congestion point queue configuration for ports associated with the specified congestion point index to default values.
| port-string | For a detailed description of possible port-string values, refer to Port String Syntax Used in the CLI in the S-, K-, and 7100 Series Configuration Guide. |
| cp-index | Specifies a congestion point index. |
| set-point | (Optional) A target value for the number of octets in the congestion point queue. CNM PDU are transmitted to the frame source queued in this congestion point's queue in order to keep the total number of octets stored in the queue at this set point. The default value is 26000. |
| weight | (Optional) Specifies the exponent used in the calculation of the quantitized feedback W value. Valid values are device specific and can be displayed using show dcb cn q-profile. The default value is 2. |
| qp-index | (Optional) Specifies a queue profile index for this congestion point. |
If no option is specified, the specified congestion point is cleared, otherwise only the optional value specified is reset to its default value.
All command modes.
This example resets the tg.1.1 congestion point queue parameter values to default values:
System(rw)->clear dcb cn congestion-point tg.1.1
Print
                        this page
Email this topic
Feedback
