Use this command to identify a DHCP client class.
| name | Specifies a name for a DHCP client class. |
None.
DHCP address pool configuration command mode.
By giving a set of client class properties a name, using this command allows you to assign properties to all DHCP clients within the class rather than configuring each client separately. This command also enables DHCP class configuration mode.
The “no” form of this command deletes a client class name.
This example shows how to assign “clientclass1” as a client class name in the “localpool” address pool:
System(rw-config)->ip dhcp pool localpool System(rw-config-dhcp-pool)->client-class clientclass1 System(rw-config-dhcp-class)->
Print
this page
Email this topic
Feedback
