Use this command to configure the cost of using the interface.
| cost | Specifies the cost of using the interface. Valid values are 1 - 16777215. The default value is 10. |
| level-1 | (Optional) Specifies that the configured cost is applied to level 1 for the interface. |
| level-1-2 | (Optional) Specifies that the configured cost is applied to both level 1 and level 2 for the interface (Default). |
| level-2 | (Optional) Specifies that the configured cost is applied to level 2 for the interface. |
If an IS-IS level is not specified, the level type defaults to both level 1 and level 2.
Interface configuration.
The “no” form of this command resets the interface cost to the default value of 10.
This example shows how to configure the cost of VLAN 100 to 15 for level 1:
System(rw)->configure System(rw-config)->interface vlan 100 System(rw-config-intf-vlan.0.100)->isis metric 15 level-1 System(rw-config-intf-vlan.0.100)->
Print
this page
Email this topic
Feedback
