Use this command to remove a tracked object from the Link-State application or to remove downstream ports from a Link-State tracked object entry.
| object-name | Specifies a port-group tracked object. |
| downstream port-string | (Optional) Specifies the downstream ports to remove from the Link-State tracked object entry. |
If no downstream ports are specified, the Link-State application entry is removed.
Command mode.
This example removes downstream port ge.1.5 from the Link-State entry for port-group tracked object ls_group.
System(su)->clear link-state track ls_group downstream ge.1.5.
Print
this page
Email this topic
Feedback
