clear port lacp
Use this command to clear link aggregation settings for one or more ports.
Syntax
clear port lacp port port-string {[aadminkey] [aportpri] [asyspri] [aadminstate {lacpactive | lacptimeout | lacpagg | lacpsync | lacpcollect | lacpdist | lacpdef | lacpexpire | all}] [padminsyspri] [padminsysid] [padminkey] [padminportpri] [padminport] [padminstate {lacpactive | lacptimeout | lacpagg | lacpsync | lacpcollect | lacpdist | lacpdef | lacpexpire | all}]}
Parameters
port port-string Specifies the physical port(s) on which LACP settings will be cleared.
aadminkey Clears a port‘s actor admin key.
aportpri Clears a port‘s actor port priority.
asyspri Clears the port‘s actor system priority.
aadminstate lacpactive | lacptimeout | lacpagg | lacpsync | lacpcollect | lacpdist | lacpdef | lacpexpire | all Clears a port‘s specific actor admin state, or all actor admin state(s). For descriptions of specific states, refer to the set port lacp command (set port lacp.)
padminsyspri Clears the port‘s default partner priority value.
padminsysid Clears the port‘s default partner system ID.
padminkey Clears the port‘s default partner admin key.
padminportpri Clears the port‘s default partner port priority.
padminport Deletes a partner port from the LACP configuration.
padminstate lacpactive | lacptimeout | lacpagg | lacpsync | lacpcollect | lacpdist | lacpdef | lacpexpire | all Clears the port‘s specific partner admin state, or all partner admin state(s).
Defaults
None.
Mode
All command modes.
This example shows how to clear all link aggregation parameters for port ge.3.16:
System(rw)->clear port lacp port ge.3.16
