clear snmp group
Use this command to clear SNMP group settings globally or for a specific SNMP group and user.
Syntax
clear snmp group groupname user [security-model {v1 | v2c | usm}]
Parameters
groupname Specifies the SNMP group to be cleared.
user Specifies the SNMP user to be cleared.
security-model v1 | v2c | usm (Optional) Clears the settings associated with a specific security model.
Defaults
If a security model is not specified, settings related to all security models will be cleared.
Mode
All command modes.
This example shows how to clear all settings assigned to the “public” user within the SNMP group “anyone”:
System(rw)->clear snmp group anyone public
