Use this command to set the number of failed login attempts before locking out (disabling) a read-write or read-only user account, the number of minutes to lockout the default admin super user account after maximum login attempts, and the number of inactive days before a non-superuser account is locked out.
| attempts attempts | Specifies the number of failed login attempts allowed before a read-write or read-only user‘s account will be disabled. Valid values are:
| time minutes | Specifies the number of minutes the default admin user account will be locked out after the maximum login attempts. Valid values are 0–65565.
| port enable | disable | Specifies port type lockout behavior:
| inactive days | Specifies the period of inactivity in days after which a non-superuser account will be locked out. Valid values are 0–65565.
| all | (Optional) Specifies that the setting is to be applied to all user accounts including super-user. |
| emergency-access user-name | Specifies the user name of an account with super-user privileges that is always available through the console. |
All command modes, Super User.
A disabled account can only be restored administratively using an account with super-user privileges. A locked out account will be accessible after a period of time has passed.
An inactivity timer value of zero means that no account will be locked out due to inactivity.
Once a user account is disabled, it can only be re-enabled by a super user with the set system login command (set system login).
The admin user is set to emergency access by default. Emergency access can only be applied to a user with super-user privileges. Except for port lockout, all other lockout behaviors are not applied to a super-user account set for emergency access, when that user is accessing the device from the console. In the case of a port being lockedout, all users are denied access to the port until the lockout expires.
This example shows how to set login attempts to 5 and lockout time to 30 minutes and the inactivity timer to 60 days:
System(su)->set system lockout attempts 5 time 30 inactive 60
Print
this page
Email this topic
Feedback
