Configure an ACE
DEMO FEATURE - Policy Based Routing (Redirect Next Hop) per VRF is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see VOSS Feature Support Matrix.
The ACL exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the ACL to which to add an ACE.
 - Click ACE.
 - Click the ACE Common tab.
 - Click Insert.
 - Configure the ACE ID.
 - Name the ACE.
 - Choose the mode: deny (drop packets) or permit (forward packets).
 - Configure the ACE actions as required.
 - Click Insert.
 - Configure the ACE attributes as required.
 - To enable the ACE, in the ACE Common tab, configure AdminState to enable, and then click Apply.
 - To delete an ACE Common entry, select the entry, and then click Delete.
ACE Common field descriptions
Use the data in the following table to use the ACE Common tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Name  |
 Specifies a descriptive user-defined name for the ACE. The system automatically assigns a name if you do not type one.  |
 AdminState  |
 Indicates the status of the ACE as enabled or disabled. You can modify an ACE only if you disable it.  |
 OperState  |
 Indicates the current operational state of the ACE.  |
 Mode  |
 Indicates the operating mode for this ACE. Valid options are deny and permit, with deny as the default.  |
 RedirectNextHop  |
 Redirects matching IPv4/IPv6 traffic to IPv4/IPv6 nexthop.  |
 RedirectNextHopVrfname  |
 Specifies the direct next hop VRF name. The name must be in the range of 1 to 16 characters.  |
 RedirectUnreach  |
 Denies or permits packet dropping when the next hop for the packet is unreachable. The default value is deny. This action is a security action.  |
 InternalQos  |
 This variable is a QoS action. The default value is 1.  |
 RemarkDscp  |
 Specifies whether the DSCP parameter marks nonstandard traffic classes and local-use Per-Hop Behavior. The default is disable. Use this option to create a QoS ACE.  |
 RemarkDot1Priority  |
 Specifies whether Dot1 Priority, as described by Layer 2 standards (802.1Q and 802.1p) is enabled. The default is disable. Use this option to create a QoS ACE.  |
