Perform this procedure to enable Perpetual PoE on a specific copper port of the switch. After you enable Perpetual PoE, you must save the running configuration file.
The following table defines parameters for the fast-poe-enable command.
                                 Variable  |
                                 Value  |
                                 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                                 Specifies the port or ports to be configured.  |
