Ensure that you apply an MKA profile to the port and associate the port with a Connectivity Association (CA) before you enable MKA on the port.
Use the following procedure to enable a MACsec Key Agreement (MKA) profile on a port.
- In the Device Physical View, select the port to which you want to apply an MKA profile.
 - Select General.
 - Select the MACsec MKA tab.
 - For MACsecMKAProfileName, select the name of the MKA profile you want to apply.
 - Select MKA Enable to enable MKA on the port.
 - Select Apply.
MACsec MKA Field Descriptions
Use the data in the following table to use the MACsec MKA tab.
| Name | Description |
                                 MACsecMKAProfileName  |
                                 Specifies the MKA profile name.  |
                                 MKA Enable  |
                                 Enables the MKA profile on the port. The default is disabled.  |
