Display information about the files in internal flash memory on this device.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select File System.
  3. Select the Flash Files tab.
Flash Files field descriptions
Use the data in the following table to use the Flash Files tab.
Name
Description
Slot
Specifies the slot number.
Name
Specifies the directory name of the file.
Date
Specifies the creation or modification date of the file.
Size
Specifies the size of the file.
