Use this procedure to display information about the multicast groups traversing the snoop enabled router.
- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click the Snoop Trace tab.
Snoop Trace field description
Use the data in the following table to use the Snoop Trace tab.
 Field  |
 Description  |
 GrpAddr  |
 Specifies the IP multicast address of the group traversing the router.  |
 SrcAddr  |
 Specifies the IP source address of the multicast group address.  |
 OutVlan  |
 Specifies the egress VLAN ID for the multicast group.  |
 OutPort  |
 Specifies the egress port of the multicast group.  |
 InVlan  |
 Specfies the ingress VLAN ID for the multicast source.  |
 InPort  |
 Specifies the ingress port for the multicast group.  |
 Type  |
 Specifies the port type on which the snoop entry is learnt.  |
