Perform this procedure to view policy information for local LLDP-MED on specific ports.
 - Click Port MED.
 - Click the Local Policy tab.
Local Policy Field Descriptions
 Name  |
 Description  |
 PortNum  |
 Specifies the port.  |
 PolicyAppType  |
 Specifies the application type.  |
 PolicyVlanId  |
 Specifies the VLAN ID for the port, as defined in IEEE 802.1Q-2003. The value 0 is used if the device is using priority tagged frames, which means only the 802.1D priority level is significant, and the default VLAN ID of the ingress port is used instead.  |
 PolicyPriority  |
 Specifies the Layer 2 priority used for the specified application type, as defined in IEEE 802.1D-2004. The default is 0.  |
 PolicyDscp  |
 Specifies the value of the Differentiated Service Code Point (DSCP) associated with a specific port on the local LLDP-MED, as defined in IETF RFC 2474 and RFC 2475. The default is 0.  |
 PolicyTagged  |
 Specifies whether the application uses a tagged or untagged VLAN, as defined by IEEE 802.1Q-2003.
