View all of the ACE Ethernet entries associated with an ACL.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click Eth.
Ethernet field descriptions
Use the data in the following table to use the Ethernet tab.
 Name  |
 Description  |
 AclId  |
 Shows the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 SrcAddrList  |
 Shows the list of Ethernet source addresses to match.  |
 SrcAddrOper  |
 Shows the operators for the ACE Ethernet source MAC address.  |
 SrcAddrOperMask  |
 Shows the source MAC address mask value in hexadecimal format if the SrcAddrOper variable is mask. The value of this field is empty or 000000000000 if the SrcAddrOper field is eq.  |
 DstAddrList  |
 Shows the list of Ethernet destination addresses to match.  |
 DstAddrOper  |
 Shows the operators for the ACE Ethernet destination MAC address.  |
 DstAddrOperMask  |
 Shows the destination MAC address mask value in hexadecimal format if the DstAddrOper variable is mask. The value for this field is empty or 000000000000 if the DstAddrOper field is eq  |
 EtherTypeList  |
 Shows the EtherType value from the Ethernet header. For example, ARP uses 0x0806 and IP uses 0x0800. Platform support determines the behavior for 802.1Q/p tagged packets. The EtherType for 802.1Q tagged frames is 0x8100. The range is 0–65535 and supports lists and ranges of values. An invalid Ether-type of 65536 indicates that you do not want the parameter in the match criteria.  |
 EtherTypeOper  |
 Shows the Ethernet type operators.  |
 VlanTagPrio  |
 Shows the priority bits (3-bit field) from the 802.1Q/p tag.  |
 VlanTagPrioOper  |
 Shows the operators for the ACE Ethernet VLAN tag priority.  |
 VlanTagPrioOperMask  |
 Shows the VLAN tag priority mask value in hexadecimal format if the VlanTagPrioOper field is mask.  |
 Port  |
 Shows the port number or port list to match.  |
 PortOper  |
 Shows the operator for the ACE Ethernet port.  |
 VlanId  |
 Shows the VLAN ID to match.  |
 VlanIdOper  |
 Shows the operator for the ACE Ethernet VLAN ID.  |
 VlanIdOperMask  |
 Shows the VLAN ID mask value in hexadecimal format if the VlanIdOper field is mask.  |
