Perform this procedure to downgrade the switch from the current trusted version to a previous release.
Important
MACsec connectivity association (CA) configurations fail during downgrade. If you plan to downgrade MACsec to an earlier version, delete the MACsec CA entries, perform the downgrade, and then reconfigure the MACsec CA entries. This applies to both 2AN and 4AN modes.
Ensure that you have a previous version installed.
The image file name is switch dependent. See VOSS Release Notes for information about file names.
The following table defines parameters for the software command.
 Variable  |
 Value  |
 activate WORD<1-99>  |
 Specifies the name of the software release image.  |
 add WORD<1-99>  |
 Specifies the path and version of the compressed software release archive file.  |
 remove WORD<1-99>  |
