VOSS User Guide Version 8.8
> RESTCONF configuration using CLI
Published September 2022
Auto-sense Fabric NNI
Auto-sense Voice without NAC
Auto-sense Voice with NAC
Auto-sense FA Proxy Switch
System Flags
Restart the platform
Enable Debug Mode
Enable Flow Control
Enable IP Directed Broadcast
Enable System Logging
Enable Automatic Reboot
Enable Trace Logs
Use the chassis shortcut menu
Use the port shortcut menu
Use a table-based tab
Undock and dock tabs
View ARP Entries
Create Static ARP Entries
Configure ARP Proxy
Operational Considerations
View BGP Route Summary
DvR Isolated Domains
DvR-VRRP Coexistence
Configure a DvR Controller
View DvR Summary
ExtremeCloud IQ Support
Configure IPsec Compression
Logical IS-IS Interface
Configure IGMP Ports
Advanced Field Descriptions
Interface Field Descriptions
Static Data I-SID
StaticIsidIpMcastRoutes Field Descriptions
Delete a Static Route
DHCPv6 Security Concerns
Configure an OSPF interface
Configure OSPF on a VLAN
Configure Port Rate Limits
Configure a Prefix List
Block SNMP Access
Changing the MSDP peer status
Viewing peer information
Viewing the local SA cache
Viewing the foreign SA cache
Viewing the mesh group
Controller configuration
Enabling the Controller
Displaying foreign sources
Enabling the Gateway
Enabling the Gateway globally
Display the IP mroute Routes
Source Specific Multicast
Peer Mesh Group
Multi domain
SPB domain interconnect
System Access
System access fundamentals
Logging On to the System
Web interface passwords
Enhanced Secure Mode
Password Requirements
Sensitive File Protection
Change the Default Username
Enabling CLI access levels
Configure an Access Policy
Creating multiple CLI users
Deleting a username
Enable a CLI User
Enabling enhanced secure mode
Configuring the reuse rule
Enable Access Levels
Configure the Logon Banner
Create an Access Policy
Enable an Access Policy
Creating Multiple Users
Modify User Passwords
Disable a User Account
Delete a User Account
Enable Enhanced Secure Mode
TACACS+ Fundamentals
TACACS+ Operation
TACACS+ Architecture
TACACS+ authentication
TACACS+ authorization
TACACS+ Accounting
TACACS+ Feature Limitations
Enabling TACACS+
Add a TACACS+ Server
Configure TACACS+ Globally
Traffic Filtering
Overview of Traffic Filtering
QoS and Filters
Access control lists
Access control entries
Operators
Attributes
Conflict and Precedence
Switched UNI ACL Filters
Traffic filter configuration
Creating an IPv4 ACL
Create an IPv6 ACL
Associating VLANs with an ACL
Associating ports with an ACL
Renaming an ACL
Disabling an ACL
Deleting an ACL
Clear ACL Statistics
Enable IPv6 Egress Filters
Viewing ACL Statistics
Clearing ACL Statistics
Configure ACEs
Configure ACE actions
Configuring ARP ACEs
Configuring an Ethernet ACE
Configure an IP ACE
Configure an IPv6 ACE
Configuring a protocol ACE
View ACE Statistics
Configure an ACE
Configure ACE Actions
Configuring ACE ARP entries
Configuring an ACE IP DSCP
Configuring ACE IP options
Configuring an ACE TCP flag
Viewing ACE Port Statistics
Data Collection for an Outage
Network Configuration
Troubleshooting Fundamentals
Connectivity Problems
Routing Table Problems
Cable Connection Problems
Alarm Database
LED Indications of Problems
Connectivity Fault Management
CFM Fundamentals
Maintenance Domain (MD)
Maintenance Association (MA)
Fault Verification
LBM Message
L2 Ping
Fault Isolation
Link Trace Message
L2 Traceroute
L2 Tracetree
L2 Tracetree-fan
Layer 2 Tracemroute
Nodal MPs
Nodal B-VLAN MIPs with SMLT
CFM Configuration Using CLI
Autogenerated CFM
Configuring Explicit Mode CFM
Configuring CFM MD
Configuring CFM MA
Configuring CFM MEP
Trigger a Loopback Test (LBM)
Trigger Linktrace (LTM)
Trigger a Layer 2 Ping
Trigger a Layer 2 Traceroute
Trigger a Layer 2 Tracetree
Trigger a Layer 2 Tracemroute
CFM Configuration Using EDM
Autogenerated CFM
Configuring Explicit CFM
Configure CFM MD
Configure CFM MA
Configure CFM MEP
Configure CFM Nodal MEP
Configure Layer 2 Ping
Initiate a Layer 2 Traceroute
Configure Layer 2 IP Ping
View Layer 2 IP Ping Results
Trigger Linktrace
View Linktrace Results
Configure a Layer 2 Tracetree
CFM Configuration Example
CFM Sample Output
Troubleshooting Overview
Debug Files
Flight Recorder
Port Mirroring
General Diagnostic Tools
Using CLI for Troubleshooting
Display NIC Counters
Using Software Record Dumps
View and Delete Debug Files
Configuring Port Mirroring
Ping an IP Device
Run a Traceroute Test
Showing SNMP Logs
Configuring I-SID Monitoring
Flush Routing Tables by VLAN
Flush Routing Tables by Port
Configure Port Mirroring
Configure ACLs for Mirroring
Configure ACEs for Mirroring
Run a Ping Test
View Ping Results
View Ping Probe History
View Traceroute Results
View the Traceroute History
Configure I-SID Monitoring
General Troubleshooting
Hardware Troubleshooting
Layer 1 Troubleshooting
Layer 2 and 3 Troubleshooting
Troubleshooting BPDU Guard
Troubleshooting IPv6 VRRP
VRRP Transitions
Troubleshooting RSMLT
RSMLT Peers Not Up
Troubleshooting vIST Failure
Multicast Troubleshooting
Using PIM Debugging Commands
Troubleshooting Fabric Attach
Troubleshooting FAN Transit
Upper Layer Troubleshooting
Troubleshooting SNMP
SNMP Trap not Received
Troubleshooting DHCP
Troubleshooting DHCP Relay
Troubleshooting TACACS+
Unable to Log On Using Telnet
Unable to Log On Using SSH
Unable to Log On by any Means
Using BGP Debugging Commands
Traps Reference
Proprietary Traps
Standard Traps
VLACP Flap Detect and Damping
VLACP Configuration using CLI
Configure VLACP on a port
VLACP Configuration using EDM
Enabling VLACP globally
Configure VLACP on a Port
VLAN Configuration
VLAN Fundamentals
Port-based VLANs
Policy-based VLANs
VLAN tagging and port types
VLAN router interfaces
IP routing and VLANs
VLAN implementation
VLAN configuration rules
VLAN Feature Support
Supported NLB Topologies
VLAN loop prevention
Switched UNI Layer 3
VLAN Configuration Using CLI
Create a VLAN
Create a Private VLAN
Limit MAC Address Learning
Configure NLB support
Configuring SLPP
Viewing SLPP information
Configuring spoof detection
Viewing VLAN information
View Private VLAN Information
View Port-Level MAC Security
View NLB-Mode Information
VLAN Configuration using EDM
Configure a VLAN on a Port
Viewing existing VLANs
Create a Port-Based VLAN
Changing VLAN port membership
Creating a SPBM B-VLAN
Configure NLB Support
Configuring SLPP globally
Configuring the SLPP by VLAN
Configuring the SLPP by port
Configuring static forwarding
Configure Limit Learning
VRF Lite
VRF Lite Fundamentals
Management VRF
Management Router VRF
VRF Lite Configuration Rules
Create a VRF Instance
Create an IPv6 VPN Instance
Configuring a VRF instance
Viewing Statistics for a VRF
VRRP Fundamentals
Critical IP Address
VRRP and SMLT
VRRP Fast Hello Timers
VRRP for IPv6
VRRPv3 guidelines
Showing extended VLAN VRRP
Viewing IP VRRPv3 Statistics
View VRRP Information
Viewing IPv6 VRRP Statistics
VRRP configuration using EDM
Enable VRRP Global Variables
Configuring VRRPv3 Checksum
Viewing VRRP Statistics
Graphing IP VRRPv3 Statistics
View IPv6 VRRP Statistics
Graphing IPv6 VRRP Statistics
VXLAN Gateway
VXLAN Gateway Fundamentals
VXLAN Gateway Licensing
VXLAN Modes
Configuring VXLAN Gateway
VXLAN Gateway show commands
Displaying VNID information
Configuring OVSDB Replication
Configuring a remote VTEP
Configuring a VNID
Configuring VNID endpoints
Configuring ELAN endpoints
Displaying the VTEP next hop
Configuring OVSDB globally
VSP 4450 Series
VSP 4900 Series
VSP 7200 Series
VSP 7400 Series
VSP 8600 Series
XA1400 Series
Interface Indexes
Port Interface Index
VLAN interface index
MLT interface index
Supported IEEE Standards
Supported RFCs
Quality of service
Network management
MIBs
Standard MIBs
Proprietary MIBs
ICMPv6 Type and Code
