You must enable IP Routing on the interface.
Use the DHCP Relay tab to configure the DHCP behavior on a VLAN. The DHCP Relay tab is available only if the VLAN is routed and is assigned an IP address.
 - Click VLANs > Basic.
 - Select a VLAN.
 - Click IP.
 - Click the DHCP Relay tab.
 - Select Enable.
 - Configure the parameters as required.
 - Click Apply.
DHCP Relay field descriptions
Use the data in the following table to use the DHCP Relay tab.
 Variable  |
 Value  |
 Enable  |
 Lets you use BootP/DHCP on the port. The default is disable.  |
 MaxHop  |
 Sets the maximum number of hops a BootP/DHCP packet can take from the DHCP client to the DHCP server. The maximum number of hops is 16. The default is 4.  |
 MinSec  |
 Represents the minimum number of seconds to wait between receiving a DHCP packet and forwarding the DHCP packet to the DHCP server. A value of 0 indicates that forwarding is done immediately. The default value is 0.  |
 Mode  |
 Indicates the type of DHCP packet required. The options are:
 The default is both.  |
 AlwaysBroadcast  |
 When enabled, the DHCP Reply packets are sent as a broadcast to the DHCP client. The default is disable.  |
 CircuitId  |
 Indicates whether DHCP Relay inserted the option 82 circuit ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable.  |
 RemoteId  |
 Indicates whether DHCP Relay inserted the option 82 remote ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable.  |
 Trusted  |
 Indicates if DHCP packets come through a trusted DHCP circuit. Only packets with GIADDR configured to 0 and containing option 82 are forwarded if the circuit is trusted. The default value is false.  |
