This procedure does not apply to VSP 8600 Series.About this task
Use this task to configure a web server certificate.
Display the web server certificate
                information:
    Switch:1(config)#web-server certificate cert-subject-name 823 Switch:1(config)#1 2021--2--2T14:35:38.865z Switch CP1 - 0x003z8604 - 0000000 GlobalRouter DIGITALCERT INFO Digital Certificate Module: Configuration Saved 1 2021--2--2T14:35:38.865z Switch CP1 Switch CP1 - 0x00040601 - 0000000 Global Router WEB INFO HTPS: Using the CA Signed Server Cert
Use the data in the following table to use the web-server certificate command
| Variable | Value |
| ca-name WORD<1-45> |
                             Specifies the name of the Certificate Authority.  |
| ca-subject-label WORD<1-45> |
                             Specifies the name of the local certificate used.  |
