Use this procedure to view the LLDP local port information.
 - Click LLDP.
 - Click the Local Port tab.
Local port field descriptions
Use the data in the following table to use the Local Port tab.
 Name  |
 Description  |
 PortNum  |
 Indicates the port number.  |
 PortIdSubType  |
 Indicates the type of port identifier.
 PortId  |
 Indicates the identifier associated with the port, on the local system.  |
 PortDesc  |
 Indicates the description of the port, on the local system.  |
