Use the following procedure to link an IPsec policy to an interface, and configure a policy direction. By default, the direction is both.
  • You must enable IPsec on the interface first, and then you link the IPsec policy to the interface.
You cannot delete or modify an IPsec policy if the policy links to a port or VLAN interface. If you need to modify the policy, first unlink the policy from the port or VLAN interface.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select IPSec.
  3. Select the Interface Policy tab.
  4. Select Insert.
  5. In the Name field, type the name of the IPsec policy.
  6. In the IfIndex field, select either Port , Vlan, or Mgmt Port, and then select an interface.
    The system displays the Mgmt Port button only for hardware with a dedicated, physical management interface. If you click this button, EDM automatically populates the IfIndex value.
  7. Select Okay.
  8. Complete the remaining optional configuration.
  9. Select Insert.
Interface Policy Field Descriptions
Use the data in the following table to use the Interface Policy tab.
Name
Description
Name
Specifies the IPsec policy name.
IfIndex
Links a policy to an interface.
IfEnabled
Shows if the IPsec is enabled on the interface and if the administrative state of the policy is enabled.
IfDirection
Specifies the direction you want to protect with IPsec:
  • inbound—Specifies ingress traffic.
  • outbound—Specifies egress traffic.
  • bothDirections—Specifies both ingress and egress traffic.
The default is bothDirections.
