Use the Trap Sender Table tab to view source and receiving addresses.
 - Click Chassis.
 - Click the Trap Sender Table tab.
Trap Sender Table Field Descriptions
Use the data in the following table to use the Trap Sender Table tab.
 Name  |
 Description  |
 RecvAddress  |
 IP address for the trap receiver. This is a read-only parameter that contains the IP address configured in the TAddress field in the TargetTable.  |
 SrcAddress  |
 Source IP address to use when sending traps. This IP address will be inserted into the source IP address field in the UDP trap packet.  |
