You can view the private VLAN information to display the primary and secondary VLANs and I-SIDs, and also view the private VLAN port types.
 - Click VLANs.
 - Click Private VLAN.
Private VLAN field descriptions
Use the data in the following table to use the Private VLAN tab.
 Name  |
 Description  |
 Primary Vlan  |
 Shows the VLAN ID for the primary VLAN.  |
 Secondary Vlan  |
 Shows the VLAN ID for the secondary VLAN.  |
 Primary / Secondary I-sid  |
 Shows the I-SID for the VLAN.  |
