Use this procedure to view the status of the Application Telemetry collector.
 - Click Application Telemetry.
 - Click the Status tab.
Status field descriptions
Use the data in the following table to use the Status tab.
 Name  |
 Description  |
 Collector IP Address  |
 Shows the address of the Application Telemetry collector.  |
             IsReachable  |
             Shows whether the Application Telemetry collector is reachable.  |
 NextHop  |
 If the collector is reachable, shows the name or address of the next hop through which the collector is reachable.  |
