To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Configure inbound filtering on a RIP interface to determine whether to learn a route on a specified interface and to specify the parameters of the route when it is added to the routing table. Configure outbound filtering on a RIP interface to determine whether to advertise a route from the routing table on a specified interface and to specify the parameters of the advertisement.
The port on which the multimedia filter is enabled becomes a DIFFSERV access port.
  1. In the navigation pane, expand Configuration > IP.
  2. Select Policy.
  3. Select the RIP In/Out Policy tab.
  4. In the desired row, double-click the InPolicy or OutPolicy column.
  5. Select a preconfigured In/Out policy, and then select OK.
RIP In/Out Policy field descriptions
Use the data in the following table to use the RIP In/Out Policy tab.
Name
Description
Address
Specifies the IP address of the RIP interface.
Interface
Specifies the internal index of the RIP interface.
InPolicy
Specifies the policy name used for inbound filtering on this RIP interface. This policy determines whether to learn a route on this interface and specifies the parameters of the route when it is added to the routing table.
OutPolicy
Specifies the policy name used for outbound filtering on this RIP interface. This policy determines whether to advertise a route from the routing table on this interface and specifies the parameters of the advertisement.
