If you enter a virtual router ID or an IP address when showing VRRP interface information, the system displays the information only for that virtual router ID or for that interface.
Switch:1#show ip vrrp interface
                                   Vlan Vrrp
VLAN VRF              VRRP IP              VIRTUAL           VERSION  ORIGIN
ID   NAME             ID   ADDRESS         MAC ADDRESS
10   GlobalRouter     37   10.10.0.254     00:00:5e:00:01:25 2        dvr
400  GlobalRouter     1    40.40.0.254     00:00:5e:00:01:01 2        config
All 2 out of 2 Total Num of Vlan Vrrp displayed
                                   Port Vrrp
PORT     VRF              VRRP IP              VIRTUAL           VERSION
NUM      NAME             ID   ADDRESS         MAC ADDRESS
               Switch:1#show ip vrrp interface verbose
                                                        Vlan Vrrp Extended
VLAN VRRP VRF                               MASTER          ADVERTISE CRITICAL        VERSION  HOSTNAME        ORIGIN
ID   ID   NAME    STATE   CONTROL PRIORITY  IPADDR          INTERVAL  IPADDR
10   37   Global~ backup  enable  100       0.0.0.0         1         0.0.0.0         2                        dvr
400  1    Global~ master  enable  100       40.40.0.12      1         0.0.0.0         2                        config
All 2 out of 2 Total Num of Vlan Vrrp Extended Entries displayed
VLAN VRRP VRF          HOLDDWN ACTION  CRITICAL BACKUP  BACKUP  FAST ADV    FAST ADV VERSION
ID   ID   NAME                 TIME    IP       MASTER  MASTER  INTERVAL    ENABLE
                                       ENABLE           STATE
10   37   GlobalRouter 60      none    disable  disable down    200         disable  2
400  1    GlobalRouter 0       none    disable  disable down    200         disable  2
All 2 out of 2 Vlan Vrrp Extended Entries displayed
VLAN VRRP VRF          MASTER ADV   PREEMPT  PSEUDO-HEADER VERSION
ID   ID   NAME         INTERVAL(ms) MODE     CHECKSUM
10   37   GlobalRouter N\A          enabled  disabled      2
400  1    GlobalRouter N\A          enabled  disabled      2
                               Port Vrrp Extended
PORT     VRRP VRF                              MASTER          ADVERTISE CRITICAL        VERSION
NUM      ID   NAME    STATE  CONTROL PRIORITY  IPADDR          INTERVAL  IPADDR
PORT     VRRP VRF          HOLDDWN ACTION  CRITICAL BACKUP  BACKUP  FAST ADV    FAST ADV VERSION
NUM      ID   NAME                 TIME    IP       MASTER  MASTER  INTERVAL    ENABLE
                                           ENABLE           STATE
PORT     VRRP VRF          MASTER ADV   PREEMPT  PSEUDO-HEADER VERSION
NUM      ID   NAME         INTERVAL(ms) MODE     CHECKSUM
Variable definitions
Use the data in the following table to use the show ip vrrp interface command.
 Variable  |
 Value  |
 gigabitethernet {slot/port[-slot/port][,...]}  |
 Specifies to show the VRRP information of which interface.  |
 verbose  |
 Specifies to show all available information about the VRRP interfaces.  |
 vlan  |
 Specifies the VLAN that contains the VRRP.  |
 vrf WORD<1-16>  |
 Specifies the name of the VRF.  |
 vrid <1-255>  |
 Specifies a unique integer value that represents the virtual router ID in the range 1–255. The virtual router acts as the default router for one or more assigned addresses.  |
 vrfids WORD<0-512>  |
 Specifies the ID of the VRF and is an integer in the range of 0–512.  |
 version<2–3>  |
 Specifies the VRRP version (2 or 3) configured.  |
