Configure a circuitless IP (CLIP) interface to provide a virtual interface that is not associated with a physical port. You can use a CLIP interface to provide uninterrupted connectivity to your device.
For scaling information and for information on the maximum number of CLIP interfaces you can configure on your device, see VOSS Release Notes.
    enable
    configure terminal
  2. Create or access a CLIP interface:
    interface loopback <1-256>
    <1-256> indicates the identification number for the CLIP.
    The command prompt changes to indicate you now access the Loopback Interface Configuration mode.
  3. Configure an IP address and name for the interface:
    ip address [<1-256>] <A.B.C.D/X> [vrf WORD<1-16>] [name WORD <0-64>]
  4. Enable OSPF on the CLIP interface:
    ip ospf [<1-256>] [vrf WORD<1-16>]
    You can configure other protocols on the CLIP interface; OSPF is the most common. See the following variable definitions table for other options.
  5. View the IP address on the CLIP interface:
    show ip interface
Create a CLIP interface.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface loopback 3
Switch:1(config-if)#ip address 23.23.23.23 255.255.255.0 name ExtNet
Switch:1>show ip interface
                          IP Interface - GlobalRouter
INTERFACE  IP            NET            BCASTADDR  REASM    VLAN  BROUTER  IPSEC    IP
           ADDRESS       MASK           FORMAT     MAXSIZE  ID    PORT     STATE    NAME
Port1/2    10.3.4.2      255.255.255.0  ones       1500     3     true     disable  address1
Clip1      1.2.3.4       255.255.0.0    ones       1500     --    false    disable
Clip2      2.3.4.5       255.255.255.0  ones       1500     --    false    disable
Clip23     23.23.23.23   255.255.255.0  ones       1500     --    false    disable  ExtNet
Vlan2      192.0.2.5     255.255.255.0  ones       1500     2     false    disable
Vlan55     55.55.55.55   255.255.255.0  ones       1500     55    false    disable  Boston
All 6 out of 6 Total Num of IP interfaces displayed
Use the data in the following table to use the ip commands.
Variable
Value
address [ <1-256> ] <A.B.C.D/X> [vrf WORD<1-16> ][name WORD<0-64]
Specifies the IP address for the CLIP interface.
<1-256> specifies the interface.
<A.B.C.D/X> specifies the IP address and mask (0–32).
vrf WORD<1-16> specifies an associated VRF by name.
The no form of this command is no ip address [<1-32>] <A.B.C.D> [vrf WORD<1-16>].
name WORD<1-16> specifies a name for the IP address.
area <1-256> <A.B.C.D> [vrf WORD<1-16> ]
Designates an area for the CLIP interface.
The default form of this command is default ip area <1-256> <A.B.C.D> [vrf WORD<1-16>]. The no form of this command is no ip area <1-256> vrf WORD<1-16>].
