Configuring VNID endpoints
Use the following procedure to configure a VNID and the VXLAN tunnel end point.
 - Click VTEP.
 - Click the Vnid End Points tab.
 - In the Vnid field, enter the VNID ID.
 - In the VtepId field, enter the ID of the remote VTEP.
 - Click Apply.
Vnid End Points field descriptions
Use the data in the following table to use the Vnid End Points tab.
 Name  |
 Description  |
 Vnid  |
 Specifies a value that uniquely identifies the VNID of this VXLAN tunnel end point.  |
 VtepId  |
 Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP.  |
 Isid  |
 Displays a value that uniquely identifies the I-SID associated with this VXLAN tunnel end point.  |
