Operational Considerations
The following section describes operational considerations for deploying Application Telemetry, including general considerations, followed by a summary of platform-specific considerations.
General Considerations
The following list describes general Application Telemetry operational considerations:
Platform-Specific Considerations
This section provides a summary of operational considerations for different switches.
Table 1. Supported flow types
Attribute
VSP 4450 Series, VSP 4900 Series, VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, VSP 8400 Series
VSP 8600 Series
Flows that ingress standard VLAN ports
Supported
Supported
Flows that ingress UNI ports
Supported
Supported
Flows that ingress NNI ports and egress UNI ports
(Layer 2 VSN)
Supported
Not supported
(Layer 3 VSN)
Supported
Not supported
Flows that ingress NNI ports and terminate locally
Supported
Not supported
Flow that ingress NNI ports and egress NNI ports
Not supported
Not supported
Flows on DvR Controllers or DvR Leafs
Supported
Supported
Table 2. Application Telemetry collector/server reachability
Attribute
VSP 8600 Series
GRT
Yes
Yes
VRF
Yes (with management CLIP)
Yes
Exception: management VRF
Fabric Connect – Layer 2 VSNs
Yes
When the Analytics Engine is reachable over a Layer 2 VSN, the GRE packets are encapsulated with MAC-in-MAC (IEEE 802.1ah) at the originating BEB. The MAC-in-MAC header is removed at the terminating BEB and the original GRE packet is sent to the collector. Note: the MAC-in-MAC encapsulation plus the GRE encapsulation adds 60 bytes to the original packet. If the original packet is close to the maximum transmission unit (MTU), the mirrored copy can exceed the MTU and be dropped.
Yes
Fabric Connect – IP Shortcut Routing
Yes
Yes
Fabric Connect – Layer 3 VSNs
No
Table 3. Coexistence with sFlow
Attribute
VSP 8600 Series
If you enable sFlow and Application Telemetry simultaneously on the same port
The switch sends the sFlow datagrams and Application Telemetry packets to the collector.
If the packet matches the Application Telemetry rules, the switch mirrors the packet to the GRE tunnel and sends it to the Analytics Engine and it cannot be sampled by sFlow.
If the packet does not match the Application Telemetry rules and the packet gets sampled, the switch sends it as an sFlow datagram to the sFlow Collector.
Table 4. Coexistence with security filters
Attribute
VSP 8600 Series
IPv6 security filters or IPv6 source guard
Not supported (consistency checks in place)
Exception: Allowed on VSP 7400 Series
Allowed
Table 5. Coexistence with mirroring
Attribute
VSP 8600 Series
Mirroring resources
Only 3 mirror ports can be configured for general port mirroring
No impact to number of mirror ports
If rx port mirroring is enabled on a port, and Application Telemetry is enabled, when a packet that matches one Application Telemetry entry criterion comes to this port
The switch generates the remote mirrored packet, and the port-based mirroring copy.
The switch generates the remote mirrored packet only. The switch does not generate the port-based mirroring copy.
If a packet does not match an Application Telemetry rule, the switch generates the port-based mirroring copy.
Table 6. Coexistence with Unicast Reverse Path Forwarding (uRPF)
Attribute
VSP 8600 Series
If you enable uRPF mode on the switch
The MTU values for both IPv4 and IPv6 packets on the same VLAN are always matched. Different Layer 3 MTU sizes on the same VLAN are not allowed in uRPF mode.
The URPF boot config flag is not applicable. Even when uRPF is enabled, IPv6 MTU can be different from IPv4 MTU; both need not be the same.
Table 7. High Availability
Attribute
VSP 8600 Series
Application Telemetry deployed in a High Availability environment
Not applicable
Supported
Table 8. Counters
Attribute
VSP 8600 Series
If packets match both user defined filters (ACLs) and Application Telemetry rules, and if both rules have counters
Both counters incremented
ACL counters incremented only
Table 9. Match off-set
Attribute
VSP 8600 Series
smb, kerberosasreq2 and kerberostgsreq packet types
kerberosasreq2 and kerberostgsreq packet types supported. Smb – not available
kerberosasreq2 and kerberostgsreq packet types supported with an off-set of 24 bytes only; an off-set of 40 bytes is not supported
