Use this task to configure IQ Agent parameters to access ExtremeCloud IQ.
You must onboard the device and configure any optional IQ Agent parameters on the supported device before you enable IQ Agent.
You can configure the IQ Agent parameters on the supported devices first, and then onboard the devices (that is, add the serial numbers for the devices in the ExtremeCloud IQ GUI) or vice versa.
For information about onboarding switches, see https://www.extremenetworks.com/support.
Configure access to ExtremeCloud IQ using an IPv4 address:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#application Switch:1(config-app)#iqagent server address 192.0.2.1
Configure access to ExtremeCloud IQ using a DNS name:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#application Switch:1(config-app)#iqagent server address extremecloudiq.com
The following table defines parameters for the iqagent server command.
| Variable | Value |
                                 address <WORD 1-255>  |
                            Specifies the ExtremeCloud IQ IPv4 address or DNS name. |
