Perform this procedure to return the ExtremeCloud IQ Agent firmware version on the switch to the version bundled with the OS image currently installed on the switch, for example, if you downgrade the OS image version and do not reconnect to ExtremeCloud IQ automatically.
  1. Enter Application Configuration mode:
    enable
    configure terminal
    application
  2. Disable ExtremeCloud IQ Agent:
    no iqagent enable
  3. Reinstall the ExtremeCloud IQ Agent firmware:
    software iqagent reinstall
  4. Enable ExtremeCloud IQ Agent:
    iqagent enable
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#application
Switch:1(config-app)#no iqagent enable
Switch:1(config-app)#software iqagent reinstall
Reinstalling IQAgent from VOSS image
Switch:1(config-app)#iqagent enable
