After the optional step of uploading the apptelemetry.pol file to flash memory using Extreme Management Center or ExtremeCloud IQ - Site Engine, activate Application Telemetry by configuring the following:
Configure the IP address of the egress interface for the GRE tunnel with the sFlow agent-ip command.
Enable sFlow with the sflow enable command.
Configure the IP address of the Analytics Engine with the sFlow collector 1 command.
Enable Application Telemetry with the app-telemetry enable command.
The following figure shows the Application Telemetry agent on various routers and switches with packets being sent to the Analytics Engine.
 Number  |
 Description  |
 1  |
 Analytics Engine  |
 2  |
 GRE tunnels  |
 3  |
 Application Telemetry agents  |
