Use the following procedure to retrieve the port egress CoS queue statistics. The system displays the statistics of the forwarded packets and bytes, and the dropped packets and bytes.
 - Click CoS Queue Stats.
 - Select the Interface tab.
Interface Field Descriptions
The following table describes the fields from the CoS Queue Stats Interface tab.
 Name  |
 Description  |
 Index  |
 Indicates the loopback port number from 192(1/1) to 241(1/50).  |
 ClearStat  |
 Clears the port egress statistics.  |
 Que<0–7>OutPackets  |
 Indicates the out packets by CoS queue number 0–7.  |
 Que<0–7>OutBytes  |
 Indicates the out bytes by CoS queue number 0–7.  |
 Que<0–7>DropPackets  |
 Indicates the drop packets by CoS queue number 0–7.  |
 Que<0–7>DropBytes  |
 Indicates the drop bytes by CoS queue number 0–7.  |
