Use this procedure to view the FA port statistics graphically.
Ensure that a switch port is selected in the Device Physical View tab.
Fabric Attach Field Descriptions
Use the data in the following table to use the Fabric Attach tab.
 Name  |
 Description  |
 DiscElemReceived  |
 Specifies the number of discovery elements received on a given port.  |
 AsgnReceived  |
 Specifies the number of remote I-SID-to-VLAN assignments received on a given port.  |
 AsgnAccepted  |
 Specifies the number of remote I-SID-to-VLAN assignments accepted on a given port.  |
 AsgnRejected  |
 Specifies the number of remote I-SID-to-VLAN assignments rejected on a given port.  |
 AsgnExpired  |
 Specifies the number of remote I-SID-to-VLAN assignments that expired on a given port.  |
 AuthFailed  |
 Indicates the number of received TLVs for which authentication was attempted and failed on the identified port.  |
 DiscElemExpired  |
 Specifies the number of discovery elements that expired on a given port.  |
 DiscElemDeleted  |
 Specifies the number of discovery elements that were deleted on a given port.  |
 AsgnDeleted  |
 Specifies the number of remote assignments that were deleted on a given port.  |
                             AsgnAuthFailed  |
                             Specifies the number of remote assignment authentications that failed on a given port.  |
