Use this procedure to view the secure channel (SC) inbound statistics using EDM.
SC Inbound Stats Field Descriptions
The following table describes the fields in the SC Inbound Stats tab.
                         Field  |
                         Description  |
                         UnusedSAPkts  |
                         Specifies the summary of received unencrypted packets on all SAs of this secure channel, with MACsec not in strict mode.  |
                         NoUsingSAPkts  |
                         Specifies the summary of received packets that were discarded along with either encrypted packets or packets that were received with MACsec operating in strict mode.  |
                         LatePkts  |
                         Specifies the number of packets received that have been discarded for this secure channel (SC) with Replay Protect enabled. Note:
                    Replay Protect is supported only by MACsec configurations using MACsec Key Agreement (MKA) protocol.  |
                         NotValidPkts  |
                         Specifies the summary of packets that were discarded in all SAs of the SC because they were not valid with one of the following conditions:
                         InvalidPkts  |
                         Specifies the summary of all packets received that were not valid for this SC, with MACsec operating in check mode.  |
                         DelayedPkts  |
                         Specifies the summary of packets for this SC, with the packet number (PN) of the packets lower than the lower bound replay protection PN. Note:
                         UncheckedPkts  |
                         The total number of packets for this SC that:
                         AcceptedPkts  |
                         Specifies the total number of Integrity Check Validated (ICV) packets for all SAs of this Secure Channel. The number of octets of User Data recovered from received frames that were integrity protected but not encrypted.  |
                         OctetsValidated  |
                         Specifies the number of octets of plain text recovered from received packets that were integrity protected but not encrypted.  |
                         OctetsDecrypted  |
                         Specifies the number of octets of plain text recovered from received packets that were integrity protected and encrypted.  |
