This procedure does not apply to VSP 8600 Series.
Use this task to view IPv4 operational routes.
 - Select Mgmt Instance.
 - Select Mgmt.
 - Select the IpRoute tab.
IpRoute Field Descriptions
Use the data in the following table to use the IpRoute tab.
 Name  |
 Description  |
 DestAddr  |
 Shows the destination address of the route entry.  |
 DestMask  |
 Shows the destination mask of the route entry.  |
 Metric  |
 Shows the metric, or cost, assigned to the route entry. If multiple entries exist to the same destination, the metric determines which route is used. Routes with a type of LOCAL have a metric equal to 1.  |
 Instance  |
 Shows the Management Instance ID.  |
 NextHop  |
 Shows the next hop for the route entry.  |
 IntfName  |
 Shows the Management Instance interface name for the route entry.  |
 Type  |
 Shows the type of route entry.  |
