Display the existing software licenses on your device. If the switch uses a Factory Default Premier Trial License, the output shows the time remaining in the trial period.
show license
Example outputs might not be identical on all hardware platforms.
The following output is shows time remaining on a Trial License for non-universal hardware when the trial period is extended:
Switch:1>show license
License Type                     : 1) BASE
                                   2) PREMIER TRIAL (non-Base features)
Premier TrialPeriodRemainingDays  : 117
Features requiring a Premier license:
        -  Layer 3 VSNs
        -  MACsec
        -  Distributed Virtual Routing(DvR) Controller
        -  VXLAN GATEWAY
        -  >16 BGP Peers
        -  Insight Virtualization
                        The following output is for a VSP 4450 Series switch that uses legacy Avaya .dat licenses. The output for the show license command for legacy licenses shows non-zero values for MD5 of Key and MD5 of File:
        License file name      :    /intflash/premier.dat
        License Type           :    PREMIER
        MD5 of Key             :    7ce34d20 0caf0074 6657d928 1b4a0a18
        MD5 of File            :    9e0e5a4c 4855efb1 90909c11 bb870d84
        Generation Time        :    2015/08/12 01:53:39
        Expiration Time        :
        Base Mac Addr          :    b4:47:5e:37:9a:00
        flags                  :    0x00000001 SINGLE
        memo                   :
        -  Layer 3 VSNs
        -  MACsec
        -  >24 VRFs
                        The output for .xml licenses on some platforms shows all zeroes for MD5 of Key and MD5 of File:
        License file name      :    /intflash/premier_macsec.xml
        License Type           :    PREMIER+MACSEC (includes Base features)
        MD5 of Key             :    00000000 00000000 00000000 00000000
        MD5 of File            :    00000000 00000000 00000000 00000000
        Generation Time        :    2015/2/26 11:09:53
        Expiration Time        :
        Base Mac Addr          :    b0:ad:aa:46:f0:00
        memo                   :
        -  Layer 3 VSNs
        -  MACsec
        -  VXLAN GATEWAY
        -  >24 VRFs
        -  >16 BGP Peers
                        The following show license command output is from a platform that supports Base Licenses per IO slot and Feature Pack Licenses.
        License file name      :    /intflash/.sys/Base.xml
        License Type           :    BASE
        Duration Type          :    Perpetual
        Generation Time        :    2017/01/05 20:57:22
        Expiration Time        :
        Host ID                :    F873A2045000
Features requiring a L3V + MacSec license:
        -  Layer 3 VSNs
        -  MACsec
        Number of IO license entitlements: 8
        License granted for slots        : 1  2  5  8
                        The following show license command output is from an XA1400 Series platform that supports Subscription Licenses.
 License file name      :    FCVPN500-EW-5YR.xml
        License Type           :    FCVPN500-EW-5YR
        Duration Type          :    TimeBased
        Generation Time        :    2019/06/10 06:50:08
        Expiration Time        :    2024/06/08
        Host ID                :    DCB808B66000
