Perform the following procedure to display information about all IP interfaces configured on the device.
Show the IP interfaces and addresses on the device:
Switch:1>enable
Switch:1#show ip interface
                          IP Interface - GlobalRouter
INTERFACE    IP             NET            BCASTADDR  REASM    VLAN  BROUTER
             ADDRESS        MASK           FORMAT     MAXSIZE  ID    PORT
Port1/6      192.0.2.6        255.255.255.0  ones       1500     200   true
Vlan100      192.0.2.5        255.255.255.0  ones       1500     100   false
Vlan4000     198.51.100.21    255.255.255.0  ones       1500     4000  false
Use the data in the following table to show ip interface command.
                             Variable  |
                             Value  |
                             gigabitethernet  |
                             Displays IP interface information for Gigabit Ethernet ports.  |
                             vrf  |
                             Displays interface information for a particular VRF.  |
                             vrfids  |
                             Displays interface information for particular VRF IDs.  |
