View the RSTP configuration information to display the RSTP-related port level configuration details.
View RSTP configuration information:
                      RSTP Port Configurations
Port Number                 : 1/1
Port Priority               : 128 (0x80)
Port PathCost               : 200000000
Port Protocol Migration     : False
Port Admin Edge Status      : False
Port Oper Edge Status       : False
Port Admin P2P Status       : Auto
Port Oper  P2P Status       : False
Port Oper  Protocol Version : Rstp
Use the data in the following table to use optional parameters with the show spanning-tree rstp port config command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
