Exception: not supported on VSP 8600 Series and XA1400 Series.
Enables MSTP and VLAN configuration on network-to-network interface (NNI) ports. The default is disabled.
Spanning Tree is disabled on all NNIs.
You cannot add an SPBM NNI port or MLT port to any non SPBM B-VLAN. You cannot add additional C-VLANs to a brouter port.
    enable
    configure terminal
  2. Enable the configuration on NNI ports:
    boot config flags nni-mstp
  3. Save the changed configuration.
  4. Restart the switch.
