View information about the neighbors on the virtual link to the OSPFv3 backbone.
- In the navigation tree, expand the following folders:
 - Click OSPFv3.
 - Click the Virtual Neighbors tab.
Virtual Neighbors field descriptions
Use the data in the following table to use the Virtual Neighbors tab.
 Name  |
 Description  |
 Area  |
 Shows the ID for the transit area.  |
 RtrId  |
 Shows the ID for the neighboring router in the autonomous system.  |
 LocalIfIndex  |
 Shows the local interface ID for the virtual link over which the switch can reach the neighbor.  |
 AddressType  |
 Shows the type of address as one of the following:
 ipv4z and ipv6z indicate a scope zone.  |
 Address  |
 Shows the IPv6 address that this virtual neighbor advertises. This value must be a global scope address.  |
 Options  |
 Shows a bit mask that corresponds to the OSPF options field of the neighbor.  |
 State  |
 Shows the state of the virtual neighbor relationship. The value can be one of the following:
