This procedure does not apply to VSP 8600 Series.About this task
View the link-state advertisements for a given area.
 - Select OSPF.
 - Select the Area Lsa Count tab.
Area Lsa Count Field Descriptions
Use the data in the following table to use the Area Lsa Count tab.
                                 Name  |
                                 Description  |
                                 AreaId  |
                                 Specifies the OSPF area.  |
                                 LsaType  |
                                 Specifies the link-state advertisement type.  |
                                 Number  |
                                 Specifies the number link-state advertisements of a given type for a given area.  |
