Use the following procedure to display status information about the OVSDB controller.
 - Click OSVDB.
 - Click the Status tab.
Status field descriptions
Use the data in the following table to use the Status tab.
 Name  |
 Description  |
 IpAddress  |
 Displays the IP address of a controller.  |
 Protocol  |
 Displays the communications protocol of a controller as TCP or SSL.  |
 Port  |
 Displays the communications port for the controller. Value range of 1 to 65535.  |
 Source  |
 Displays the source of the controller as learned or configured.  |
 OperStatus  |
 Displays the operational status of the controller.  |
