Add or remove the ports in a VLAN to configure the ports in the VLAN.
Add ports in a VLAN:
Switch(config-if)# vlan members add 1 1/2 static
Remove ports in a VLAN:
Switch(config-if)# vlan members remove 1 1/2 notallowed
Use the data in the following table to use the vlan members add and vlan members remove commands.
                             Variable  |
                             Value  |
                             <1-4059>  |
                             Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                             portmember  |
                             Configures the port type as port member.  |
