This procedure only applies to VSP 4450 Series.
View port routing statistics to manage network performance.
  1. In the Device Physical View, select a port.
  2. In the navigation tree, expand Configuration > Graph.
  3. Select Port.
  4. Select the Routing tab.
Routing Field Descriptions
Use the data in the following table to use the Routing tab.
Name
Description
InUnicastFrames
The number of incoming unicast frames routed.
InMulticastFrames
The number of incoming multicast frames routed.
InDiscards
The number of frames discarded by the routing entity.
OutUnicastFrames
The number of outgoing unicast frames routed.
OutMulticastFrames
The number of outgoing multicast frames routed.
